Need help with cam selection
Old 07-19-2009, 07:32 PM
91 Fox 331
91 Fox 331's Avatar
Default Need help with cam selection
Im building a 331 in the next month and for now it is going to be run N/A and i would like a nice street cam for it. My last cam was a trickflow 275 I/245 E i not sure on the duration on the exhaust. My lift wasnt that much and i was wondering if anyone had a good sugestion for a street/strip cam with a power band 2,500-6,500. Im lookin for 400 wheel N/A. As of right now im not going to custom grind a cam, that will be for when i throw on my twins I will put on in the future.
I need help because im lookin to have the car finished this fall and i already have everything else down to my clutch and water pump figured out, this is my last issue.
91 Fox 331 is offline
Old 07-19-2009, 08:55 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
i was gonna say custom but since you don't want that now...look at the comp afi stroker cams then
mjr46 is offline
Old 07-19-2009, 09:14 PM
91 Fox 331
91 Fox 331's Avatar
Are you talking about the XFI stoker cams, i looked at those and they recommeneded them for a 347 or larger. I was lookin at it, 248in/258ex at .050" lift and ill be running a 1.6 roller rocker for now. Do you think that would be good with a set of TFS twisted wedge heads. Im not too worried about valve clearence because ill have dished pistons to drop my compression.
Old 07-19-2009, 09:45 PM
mjr46
mjr46's Avatar
yes...just a typo.......I'd get some bigger heads
mjr46 is offline
Old 07-19-2009, 09:51 PM
91 Fox 331
91 Fox 331's Avatar
I plan on buyin bigger, just right now im lookin at almost 6 grand to get my car movin again so another 2 for heads just aint possible right now. but i plan on running TFS again but CNC ported, would like to flow closer to 300 cfm, im at 235 cfm right now.
Are those cams reliable on the street because ill see more crusin woodward than i will the track. I know my last cam i had a problem running below 1500 rpm while in gear, the car wanted to surge and shook everything.
Old 07-19-2009, 10:01 PM
mjr46
mjr46's Avatar
most roller cams are around the 270 range that are decent, custom is only 30 beans more, and the valve events can be taylored to your needs and combo right now......I just pulled a cam from my 89 that's to aggressive for my liking and use, to avoid idle issues I'm gonna have a custom cam designed light on the duration side and semi agressive on the lift, and whatever else the designer feels I can benifit from
mjr46 is offline
Old 07-19-2009, 10:10 PM
91 Fox 331
91 Fox 331's Avatar
well i dont plan on running this cam with the twins im going to put on it, that will be a completely new top end when i do that.
who are you having grind your cam or who would you recommend besides camshaft inovations?
GimpyHSHS
19
12-19-2023 01:12 PM
carid
07-08-2016 09:55 AM
patchshaffer
Tuner Central
10-05-2015 02:24 PM
uedlose
The Racers Bench
10-01-2015 08:31 PM
junior04
09-28-2015 10:53 AM
Quick Reply: Need help with cam selection
