body control module
Old 07-19-2009, 10:00 PM
morgan62
morgan62's Avatar
Default body control module
im having trouble getting my car running right i have tried every thing could the body control module make my car miss like it is not getting gas at the right time,thanks alot
morgan62 is offline
Old 07-19-2009, 10:04 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
you don't have CAN in your obd 1 mustang, it is not on a network per say where bcm exists.....now you do have an ecm.......what have you tried and what is the exact issue at hand
mjr46 is offline
Old 07-19-2009, 10:15 PM
morgan62
morgan62's Avatar
i believe it is the ecm i believe because my fuel pump will not run unles i hook it up straight off of the battery the injecors dont seem to open at the right time i have set my tmming when you first crank it it sounds good and takes gas but after a few seconds its like it running out of gas chaged the fuel pump and the fuel pump regulator
morgan62 is offline
Old 07-19-2009, 10:30 PM
morgan62
morgan62's Avatar
al so i talked to a mechanic he said it cotrolled your injectors fan and other componets,please reply could this be it i haved tried every thing
morgan62 is offline
jwog666
12-27-2021 08:09 PM
folivier
10-02-2015 05:34 AM
GLOCKer
09-28-2015 07:36 AM
2poor4u2
09-26-2015 11:08 AM
ThatJuanStang
09-25-2015 08:01 AM
Quick Reply: body control module
