ecm
ecm
is it possible it could be the ecm i changed the fuel pump regulator i had to hook the fuel pump straght before it would run but you first crank it it sonds good for a couple seconds the it acts like the injectors are not opening up right,and it seems like it is running of of gas but i no i got fuel pressure
dude wtf im having problems too, I changed my fuel pump yesterday because it crapped out while my brother was driving. I put everything back together and the pump will turn on most of the time but it just stays on it wont just shut off and prime. I did get it to run like 3 times today but anyways. have you put a test light on the injectors to see if thay are pulseing like thay are supposed to? also have you done a fuel pressure test to see if your getting fuel to the injectors?
Before you start throwing parts at the problem, suggest to start with the DIY KOEO/KOER self test procedures. LUK
