overheating problem
overheating problem
every i drive my car hard it overflows the reserve tank and its like boiling and also when i get to a stop my temp needle starts to climb to like the third line to the last but once i take off and get some speed needle starts to drop, and once i turn car off and let it sit radiator starts to suck coolant back in , but when driving normally it doesnt happen, could i have a bad fan or clogged radiator
I'd start with replacing the clutch fan, make sure system is bled properly throw on a new radiator cap and if it still does it after that , it may have a partially restricted radiator but I'd assume a fan first
it would be a good idea to start with the fan and fan clutch. Also check if your fan is spinning while your car is on. sometimes the shroud can slip down and prevent the fan from spinning and cooling properly.
well yesterday i was looking at it and noticed my belt was rubbing with water pulley and tensioner, so i replaced the belt, i guess old one stretched, and i also noticed that sometimes u can hear the fan spinning and blowing air and somtimes u cant, and my fan does not feel as tight as it use to when turning it by hand so im either going to replace clutch fan or upgrade to electric
mungodrums
09-29-2015 09:18 PM
stangin1996gt
09-21-2015 11:01 AM
yourmom6990
09-14-2015 10:52 PM
