TB question
Old 07-21-2009, 08:07 AM
stangman24
stangman24's Avatar
Default TB question
My stock and new 65mm tb have different elec plugs for the egr and i was wondering if it mattered if i switched them. Also my stock tb and my new 65 mm tb have different location where the throttle cable hooks up at. I was thinking of routing the cable a better way so it would line up better to have a smoothercable pull when hitting the gas. Any help would be appreciated.
stangman24 is offline
Old 07-21-2009, 08:27 AM
AdderMk2
Banned
AdderMk2's Avatar
pics of both... or ban
AdderMk2 is offline
Old 07-21-2009, 10:48 AM
Tony71502
Tony71502's Avatar
The egr has no electrical connection to the throttle body... it bolts on the egr spacer. You must be thinking of the throttle position switch.
Tony71502 is offline
Old 07-21-2009, 03:42 PM
stangman24
stangman24's Avatar
so nobody knows if the elec connector will be interchangeable with my stock and the new 65mm throttle body? I should need a pic b/c i am sure you know what elec connector i am talking about on the Tb b/c its the only elec connector. Only thing diff is the plastic clip
Old 07-21-2009, 03:55 PM
AdderMk2
Banned
AdderMk2's Avatar
if i knew what connetor you were talking about, i wouldnt friggin have asked for pics...
the tb doesnt have any electrical connectors. however, the tps and iac both connect to it. so how about you post pictures of what you are talking about, because you clearly havent got a clue, and we aren't psychic
AdderMk2 is offline
Old 07-22-2009, 08:36 AM
stangman24
stangman24's Avatar
intake air temp sensor.
Dokilar
15
10-16-2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
treesloth
09-28-2015 07:03 AM
Quick Reply: TB question
