How do I go about fixing this code?
Old 07-21-2009, 03:27 PM
nacanitihs
nacanitihs's Avatar
Default How do I go about fixing this code?
ok so when im driving my CEL comes on and off. i decided to run the codes. KOEO i got an 11 system pass. with the KOER test i got 41, 33, and 99.
41 - No HEGO switching detected always lean (right side).
33 - EGR valve opening not detected.
99 - EEC system hasnt learned to control idle. (got this doing the cylinder self balance test)
well the 33 i assume my erg is screwed but i have a diff one, plus i have no smog stuff
the 99 i just reset the idle and only drove it like 3 miles and it wasnt even warm when i reset it so i gotta do it again.. (surges a little)
but what do i do about the 41? i honestly dont know what to do.. anyone have a solution?
thanx
nacanitihs is offline
Old 07-21-2009, 04:46 PM
AdderMk2
Banned
AdderMk2's Avatar
reset the codes and swap your o2 sensors from right to left. drive the car and re-run koer and see if it comes up with a 91 ... if you get a 91, you have a bad o2. if it stays 41, you have a wiring problem.
AdderMk2 is offline
Old 07-21-2009, 06:36 PM
nacanitihs
nacanitihs's Avatar
ok ill give that a shot. hopefully its just a shot o2 sensor. i wouldnt want to play that other game...
Old 07-21-2009, 06:50 PM
safado
safado's Avatar
+2 on the swap diag
safado is offline
Old 07-22-2009, 12:23 AM
NotchAbove
NotchAbove's Avatar
33 - Is due to not having a vacuum line to your EGR.
The 99 your getting isn't what you think. 9 / 9 on the Cylinder Balance Test indicates all cylinders are in balance. It flashed code 9 twice, hence 99.
41 has been addressed already.
Good Luck.
NotchAbove is offline
Old 07-22-2009, 07:26 PM
nacanitihs
nacanitihs's Avatar
ok sweet looks like i need an o2
BOB ROME
07-26-2023 01:54 PM
Thunderball
15
11-22-2015 11:49 PM
Dathan
10-05-2015 05:52 AM
wraith777
09-28-2015 10:49 AM
Quick Reply: How do I go about fixing this code?
