which valve springs?
Old 07-21-2009, 07:25 PM
86 5.0Lmustang
86 5.0Lmustang's Avatar
Default which valve springs?
93 5.0L motor stock heads, gt 40 upper lower intakes, 65 mm explorer t, e303 cam, 1.6 rr's
which valve springs should i be looking at? would stock work or shuld i upgade. kinda on a budget to
86 5.0Lmustang is offline
Old 07-21-2009, 07:38 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
ford racing recommends the A-50 springs and B-50 retainers , go on summits website type in your cam and hit the suggested parts link and you'll see what you need
mjr46 is offline
Old 07-23-2009, 09:27 PM
86 5.0Lmustang
is there anyway i can find out if there is a cam in this car already without pulling it out?
if i got the stock cam, and decide not to replace it, can i upgrade the springs and retainers? im going with 1.6 rr;s
Old 07-24-2009, 04:30 PM
86 5.0Lmustang
to the top
Old 07-24-2009, 06:16 PM
mjr46
mjr46's Avatar
with the proper dial indicator, you could measure lift
mjr46 is offline
Old 07-24-2009, 10:06 PM
86 5.0Lmustang
i got one of those with a magnetic base, how do i measure that
Old 07-30-2009, 05:01 PM
86 5.0Lmustang
to the top
Old 07-30-2009, 07:28 PM
Joel5.0
Joel5.0's Avatar
Measure tappet lift, multiply by rocker ratio = valve lift and check what cams may provide that lift........
Or you could degree the cam and find out exactly what cam is installed = http://www.lunatipower.com/Tech/Cams...egreeACam.aspx
Joel5.0 is offline
GimpyHSHS
19
12-19-2023 01:12 PM
mrtrodonet
09-19-2020 03:12 PM
CS2007
06-25-2019 09:45 PM
mungodrums
09-28-2015 10:54 PM
Quick Reply: which valve springs?
