Vibration issue....u-joint? mount? trans? bearing?
Alright...I have a 1990 5 spd 5.0 mustang thats fairly stock.
My transmission shifter has always vibrated at higher speeds but lately when I'm in 5th gear its starting to get unbearable. I've noticed when I'm in 5th and only in 5th I get a very bad shudder that hits at 55 mph. It almost feels like I'm tapping the brakes while simultaneously giving the car gas. To better describe it.....it feels like something is binding up for a few seconds. Then I accelerate out of it. There is still a vibration there just not as pronounced. The vibration almost disappears by the time I hit 70. If I drop the vehicle into neutral the vibration goes away. If I take the vehicle over 55 in 4th or 3rd I still get a bit of vibration but not the strange dragging feeling that occurs for a few seconds right at 55mph. If I put the vehicle into 5th at a speed over 55 mph the binding feeling never occurs. The vibration is mainly felt in the center to the rear of the vehicle. It is especially strong in the shifter handle.
The clutch feels great. My tires aren't the best. Wheels are not bent. I checked the U-joints last around 15,000 miles ago and they were fine. I have a very very tiny trans leak, a little spotting if I let the car sit for a few days. I used to drive the car daily, 80 miles a day. Now the car sits for most of the week. I have noticed it more since the car has not be driven as frequently. I've had the car since 112,000 miles. It has a 141,000 on it now. I noticed today when I looked under the vehicle that my h-pipe is coming apart at the center of the H. I noticed my car was getting noiser before the vibration problem developed however.
any ideas will help...I'm thinking about changing the u-joints just because they're probably due. I didn't see any problems with the harmonic balancer. If I rev the car at a stand still I get no vibration. Thanks.
http://www.summitracing.com/parts/FMS-M-4602-G/
Here is a link for it at summit, it's like $250, but well worth it!
well.... checked the u joints and they were good. Transmission fluid was the right color and smelled fine. I welded the exhaust back together. Checked the rear end fluid which was a little low and reeked. Took off the cover. Gears looked fine. No metal shavings or such. Replaced the fluid. I didn't see any weights on my driveshaft. I don't know much about driveshafts to be honest with you and I don't know if it has to have them. The feeling definately got better. The shake in the shifter has diminished but I still get a very strange vibration throughout the car in 5th only around 55 mph.
Geesh and the hole in the exhaust. I forgot how quiet my car really was. The car drives much smoother with a noticable increase in power.
I guess replacing the driveshaft might be the next step
It seems like every driveshaft and drive axle place has gone under in my town.....
Am I better off just replacing the drive shaft or should I just get it balanced.There definately weren't any weights on the shaft. How much does balancing a driveshaft normally cost? Any ideas?
I did check the torque on all of the bolts in the vicinity. Thanks for the suggestion.
jwog666
12-27-2021 08:09 PM
KingRando
10-02-2015 08:06 AM
