89GT Dyno Tuning? Help!
Hello all. I just recently bought an 1989GT coupe, the motor is rebuilt. I am having trouble finding a shop who will do a reliable dyno tuning. I currently live in delaware county. Please all the help i can get or even if you put me in the right direction would be greatly appreciated.
I have had a bad experience with Tillman's (they dodged me for over six weeks, and when they finally tell me they will do my car, they don't even touch it for over two days.)
I have called Evolution, but they do not work on older mustangs.
Thank you-
Thank you-
OP you need to give us some more information about your car. what if anything, do you have done to the car
well, i believe it needs a good tuning because:
From the start :
New sportsman block bored .30 over with a fordged bottom end.
Twisted Wedge Alum 351 heads w 1.6 ratio alum rockers
Custom made Camshaft
Trickflow upper and lower intake.
C&L EGR delete plate
C&L 75 mm throttle body
BBK Adjus Fuel Pressure Regulator
30# fuel injectors
90mm mass air flow sensor calibrated for 30# injectors
BBK Cold air intake
MAC long tube headers
Flowmaster 2.5" off road X pipe with 40 serires mufflers
Crane Cam HI-6 Box with matching Flamethrower coil
Crane Cam Street/Strip digi distributor
C&L Underdrive pulleys
A/C delete braket
Alum Radiator w/ electric fan
Walbro 255 lph in-tank fuel pump
Rebuilt T-5 with Ford Racing flywheel and clutch
Steeda Clutch Quandrant Kit w/ firewall clutch adjuster
Steeda Tri-Ax Shifter
3.73 Gears
....and some other things are done. The car isnt running like i know it can. ... can you help me?
From the start :
30# fuel injectors
BBK Cold air intake
A/C delete braket
3.73 Gears
It bucks out at 3grand and it smells like straight fuel. Everyone keeps telling me to push the fuel pressure up and it just isnt working..... I only got about 1,000 miles on the motor and it was never dyno tuned yet...
If it smells like raw fuel then it's flooding it. If anything fuel pressure needs to go down. What do you have it set at?
Also, what brand MAF is on your car? As unless you have a REAL good one, that MAF may be your problem, 90mm is WAY too big for your set-up, may not be getting a proper reading.
It shouldn't have to be tuned. My 408 with 42# injectors runs almost perfect right off the factory PCM. Runs at about 13.7:1 under load. FP set at 36lbs
