Knock Issue-Flexplate?
I need some help . I just dropped in a new motor. I installed a new SFI approved flexplate and a 2800 stall ACC converter. I now have a problem.
On a cold start it sounds great. After it reaches operating temp it sounds terrible. A loud knock with rpms when in park or neutral. Almost sounds like a rod knock but it completely disappears when you put it in gear. During driving there is also no noise and it pulls and drives fine with good oil pressure-25psi at hot idle. I crawled under and it sounds like it is coming from the bellhousing.
I pulled the inspection plate and checked the TC nuts-two were loose. Not real loose but a couple turns. I read that may have been enough to throw the plate off balance and crack it. I couldn't see any cracks when I looked though. I also did the shade tree mechanic thing and listened with a screwdriver and seemed to trace the sound there
Any ideas on what may be causing the noise? Could the converter be bad? Did the loose nuts crack the plate?
Help
Thanks
_________
Help
Thanks
_________
Would that sound go away when put in gear? Seems llike it would be constant
Thanks
jessicarabbit
09-25-2015 12:41 PM
