Power valve block off???
I dont have a vacuum gauge.. what if i was to buy one that is to big or to small? The carb is a holley 700 double pumper..
The car will run rich or lean or might have other issues if the power valve is not sized right. If the car was running good, just replace it with the same size. On a side note, if you go with a block off, you will need to jet up approx 4 sizes. BTW, it an easy job to install a PV blow out protection, Summit sells them.
Do not block the power valve off,it will not have the proper A/F ratio thru out the entire range.With out getting to in depth,emulsion tubes and air bleeds are not set up for adding that much jet and in most cases it could be up to ten jet sizes larger. Generally, Holley installs a 6.5" power valve ,which works in most cases.If the base plate does not have a backfire check valve in it,it is very easy to add one.Then figure out why it is backfiring,so as to not ruin anymore.
Most Holley power valves have it stamped on them what 'size' they are. It's down by the flats on the thing. Look for something like '65' or '70'. Meanig 6.5 or 7.0.
I wouldn't do the power valve plug thing for a couple of reasons.
1) If they were a good idea, Holley would have built them that way.
2) I've tried it and there is always a bunch jetting problems, just making for a lot of make work..
TfcCDR
09-14-2015 12:08 PM
09-08-2015 05:21 PM
