Cloud if smoke from tail pipe when I floor my car
Old 08-02-2009, 11:08 PM
84foxT
84foxT's Avatar
really now, so your saying that there is no oil going to the rocker arms or valve springs or anything on the head...............an if you think that you will also tell me i dont need valve covers
84foxT is offline
Old 08-03-2009, 12:24 AM
domindart
domindart's Avatar
All Im saying is that sometimes smoke comes out when you floor it. You dont want to confuse this with "engine rebuild time".
domindart is offline
Old 08-03-2009, 09:29 AM
projectresto83
M.A.D. Motorsports
projectresto83's Avatar
Noooo, what was being said is that the oil that is at the valve seals isn't really under any pressure. So raising the oil pressure by hitting the throw isn't going to may them leak more do to the pressure.
projectresto83 is offline
Old 08-03-2009, 12:07 PM
19stang88
19stang88's Avatar
I saw a pretty good built 03 04 cobra and when is nailed the gas smoke came out of the tail pipes, i don't the motor was toast. But in 89MustangGT89 case, you might be nailing the gas while the motor is still cold making it run rich.
19stang88 is offline
Old 08-03-2009, 02:11 PM
ryan_89_mustang
ryan_89_mustang's Avatar
Running rich creates black smoke. Blue smoke is oil bad valve seals usually create a blue puff on start up and all the time whether you're flooring it or not. Worn rings cause more blue smoke under load.
ryan_89_mustang is offline
Old 06-19-2011, 01:42 AM
89MustangGT89
89MustangGT89's Avatar
so if i were to rebuild the engine the problem would be fixed basically?
89MustangGT89 is offline
Old 06-19-2011, 01:48 AM
302army187
302army187's Avatar
lol @ two year old thread.
if its run two years like that, it will probably be alright for a bit longer
302army187 is offline
Old 06-19-2011, 03:13 AM
AdderMk2
Banned
AdderMk2's Avatar
Ive posted about this stuff several times.... People will learn to search eventually.
Blue smoke under hard acceleration: Piston Rings
Blue smoke under engine deceleration: Valve Guides
Blue smoke on cold start: Valve seals
You car likely has a crankcase pressurization issue that is causing oil to get up into your cylinders. OR, your PCV system is sucking in too much oil, causing it to pool in the intake and run down into the cylinders.
AdderMk2 is offline
Old 06-19-2011, 06:00 PM
89MustangGT89
lol i was looking thru all my post and just realized someone replied
Old 06-19-2011, 06:20 PM
tohoopty
tohoopty's Avatar
ok so in the 2 years since you made this thread,what does it run like now
tohoopty is offline
Quick Reply: Cloud if smoke from tail pipe when I floor my car
