help after H/C/I
Old 08-02-2009, 03:40 PM
f1atlander
f1atlander's Avatar
Default help after H/C/I
my car was stock other than CAI and flowmasters. in a month i gathered up some long tubes w/ off road h pipe, gt40p heads, explorer upper and lower and tb, and a timing gear-drive set i thought was quiet. headers wouldnt fit w/ this slush box auto trans. so i put the stock headers on and of course w/ the p heads i had problems. but working at a muffler shop, i took care of that enough to get by. my ? is what kind of tuning needs to be done after this hci swap? still not feeling a differance like i though i would. im thinking fuel. but im new to F/I so im lost when tuning if it aint a carb. thanks in advance. what kind of power should i be makin with this setup?
f1atlander is offline
Old 08-02-2009, 06:59 PM
95stang gt
95stang gt's Avatar
my guess would be 250-260 hp. take it to a dyno and get it tuned that way.
95stang gt is offline
Old 08-02-2009, 07:45 PM
f1atlander
f1atlander's Avatar
i just took it out and the oil pressure is dropping at idle in gear. its in the center in nuetral and at any rpms above 800. then if i put it in gear it just drops and bounces back up. i was afraid you would say to get it tuned. $$$$$$
Old 08-02-2009, 07:52 PM
95stang gt
95stang gt's Avatar
it does cost money but its well worth it in the end
Old 08-02-2009, 08:01 PM
ctgreddy
ctgreddy's Avatar
I believe the auto's had the a9l computers still didn't they? if so you don't really need a tune with that, especially since your keeping the same cam, or so it sounds. I'd guess around 250 whp with the slushbox. If you work at a muffler shop you should be able to make the longtubes work with the trans tho.
ctgreddy is offline
Old 08-02-2009, 08:47 PM
f1atlander
f1atlander's Avatar
well i did change the cam and the worst part is that i got it used, from a friend and it had a bad stamp on the back so i couldnt get the #s to find out what it is. he said it had more than his E cam. but it isnt to rad at idle. i was goin to do that to the headers/h pipe but i plan to go to a t5 in a couple weeks anyway.
Old 08-02-2009, 09:17 PM
XPBaller
XPBaller's Avatar
That dropping oil pressure at idle would have me REAL concerned.
XPBaller is offline
Old 08-02-2009, 09:36 PM
OnyxCobra
OnyxCobra's Avatar
you're gonna need a tune to get it running optimally...
OnyxCobra is offline
Old 08-02-2009, 09:45 PM
f1atlander
f1atlander's Avatar
oh trust me i does but no valvetrain racket. im thinkin the sending unit and hoping that i didnt ster up some junk and clog up the pick up screen
Old 08-02-2009, 09:47 PM
f1atlander
f1atlander's Avatar
really?? man this computer controlled stuff is expensive
Quick Reply: help after H/C/I
