door wont open
Old 08-02-2009, 04:34 PM
1988GTstang
1988GTstang's Avatar
Default door wont open
today i found out my passenger door wont open u hit the unlock and it wont unlock..i tried opening the handle from the inside and it did nothing..even trying to unlock it with the key from the outside and it wont turn and if i put anymore pressure ill break the key...wut the heck is going on!
1988GTstang is offline
Old 08-02-2009, 05:45 PM
Boss_Hotrod
Boss_Hotrod's Avatar
Actuator is locked up. You can unhook the rod to unlock it with the key until you get a replacement.
Boss_Hotrod is offline
Old 08-02-2009, 07:18 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
sounds like the actuator is siezed, remove door panel and unhook rod and replace it
mjr46 is offline
Old 08-03-2009, 02:10 AM
1988GTstang
The key won't unlock it it won't turn how do I get the door open
Old 08-03-2009, 09:25 AM
projectresto83
M.A.D. Motorsports
projectresto83's Avatar
You don't. Remove the panel with the door closed....
projectresto83 is offline
Old 08-12-2009, 12:29 PM
1988GTstang
wanna tell me how to do that?
Old 08-12-2009, 01:41 PM
projectresto83
M.A.D. Motorsports
Well first you won't be able to get it all the way off probably bc of the dash BUT you can get it off enough to pop the rod off to open the door. Take the caps off your arm rest and unbolt that. Unplug your power switch, if you have manual windows the unscrew the handle and remove it then grab the corner of the panel and pull to start popping the door panel off. Try and be gentle with it though. Its not that hard. It will flex enough to get where you need to get to.
Old 08-12-2009, 08:36 PM
mjr46
mjr46's Avatar
you can remove the arm rest and then pop the side loose and then reach in and undo the rod...it'll be tight but it can be done
mjr46 is offline
Old 08-12-2009, 09:17 PM
mustang_saleen_gt
mustang_saleen_gt's Avatar
wow......
mustang_saleen_gt is offline
jerrytubes
10-23-2015 12:11 PM
Florida Regional Chapter
09-30-2015 08:04 PM
Sixer4Life
09-29-2015 07:03 PM
09-25-2015 06:58 PM
Quick Reply: door wont open
