5.0 trouble!!!
5.0 trouble!!!
Im having some trouble with my car under acceleration. When i drive it normally it feels alittle held back but still runs ok. But at certain times when i start to give it alot gas on second gear it will bog down and not go anywhere. The rpms drop to about 1000 and just bogs. Its a 1990 5.0 lx stick shift. Ive recently changed my intake manifold cause it was cracked and causing my car to backfire. It still backfires at times mostly in the rain thou. Im also running the car without the aftermarket filter at the moment because when i had it on it would backfire more often. I want to get this fixed but am not to sure whats the problem. I also have a bad rear main seal causing the car to leak oil and smoke alittle i dont know if that has anything to do with it. I brought the seal and am going to put on this weekend but i would like to take care of that backfire and bogging issue to. Any help would be appreciated. ty
could be a fuel pump getting weak causing a lean pop out the back and no fuel at other times
i would try a maf if I had one lying around
maybe check the fuel pump relay too
Matt's 95 Stang
10-05-2015 07:16 AM
