fuel pump trouble
Old 08-04-2009, 04:08 PM
atwood1
atwood1's Avatar
Angry fuel pump trouble
on my 87 mustang i have no fuel pump power i have replaced all the relays including the eec relay i turn the key and no fuel pump my fuel pump works tho because i tested it Any Ideas please help
atwood1 is offline
Old 08-04-2009, 09:12 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
have you checked for power to the fp relay under the seat?
mjr46 is offline
Old 08-04-2009, 10:23 PM
atwood1
atwood1's Avatar
yea there is power to it there is supposed to be a power and 2 grounds and there is a power and a ground and i cant find any broken wires but if i hot wire it the pump will turn on
atwood1 is offline
Old 08-04-2009, 10:37 PM
mattdel
mattdel's Avatar
inertia switch
mattdel is offline
Old 08-04-2009, 10:47 PM
atwood1
atwood1's Avatar
Originally Posted by mattdel
inertia switch
where is that
atwood1 is offline
Old 08-04-2009, 10:48 PM
SonicBlueFiveSlow
SonicBlueFiveSlow's Avatar
In the back attached to the tail light panel I believe.
SonicBlueFiveSlow is offline
Old 08-04-2009, 10:51 PM
atwood1
atwood1's Avatar
Originally Posted by SonicBlueFiveSlow
Under the drivers seat as well
ok sounds good i was also told by the drivers tail light there is a shut off switch i can check
atwood1 is offline
Old 08-04-2009, 10:55 PM
SonicBlueFiveSlow
I edited my post, the intertia switch is by the drivers side tail light...I don't know why I said under the drivers seat lol.
Old 08-04-2009, 11:02 PM
atwood1
atwood1's Avatar
ya i saw that right after i posted that
atwood1 is offline
Old 08-05-2009, 07:41 AM
mjr46
mjr46's Avatar
if the inertia switch is not tripped then you need to see why the ecm is not grounding the relay coil for the f relay....there should be a larger gauge wire hot and the one that becomes hot when relay windings are pulled in which then makes the wire to FP hot hence FP operation....the two smaller wires = 1 switched 12 for relay windings and the other is the ecm ground for windings = controlled by ecm when PIP is seen, PIP is generated/filtered by the tfi on the dizzy, stator in the dizzy Id's tdc and tfi transmits info to ecm where it is all interpereted as inputs and from there ecm performs output functions such AS grounding the windings to the fp relay
mjr46 is offline
Quick Reply: fuel pump trouble
