Power/Shift problem
Old 08-07-2009, 11:43 AM
Holy_Joe
Holy_Joe's Avatar
Default Power/Shift problem
In my 95 gt ive been having some problems like the tranny shifting way to early and its lugging the motor, but then it works correctly when in want to. When i drive it and it shifts into a higher gear, the rpm starts to drop while im giving it gas, nothing works until i push it to the floor to drop into a lower gear, but then it seems like there no power when it shifts. Theres no check engine light on. Its got the AODE Electronic four speed w/overdrive. The transmission fluid, filter, and gasket have been changed. The neutral safety switch and throttle position sensor have been replaced, they were fried when i got the car. Any suggestions?
Holy_Joe is offline
Old 08-11-2010, 09:45 AM
Daddiofink
Daddiofink's Avatar
Did you ever resolve this issue? Similar problem with an AOD.
Thanks
Daddiofink is offline
Old 08-11-2010, 06:15 PM
enix187
enix187's Avatar
tv cable is probably not hooked up, its the second line next to the throttle cable on the throttle body, bump from the dead
enix187 is offline
Seanam
10-04-2015 10:15 AM
mdj89
09-23-2015 08:49 AM
kachuy10
09-22-2015 01:27 PM
stangin1996gt
09-21-2015 11:01 AM
Big Al's 03
Mach 1 Section
09-21-2015 07:59 AM
Quick Reply: Power/Shift problem
