Idle problem. Just a question.
Old 08-07-2009, 03:05 PM
Ze2222
Ze2222's Avatar
Default Idle problem. Just a question.
Hi guys i've been trying to chase down my idle problem, car wants to idle at 1200. Well i tried resetting base idle but can't even with throttle stop screw all the way out still idles at 1200, except when cold then it'll start up and idle at 800 then after 10 mins will stay at 1200.
so i did some reading and looked on mitchelle on demand, they say check for vacuum leaks, i sprayed everywhere down with ether no change in idle, measure voltaged while unit was running from the iac, had voltages from 1.7 volts to 5 volts while changing idle, measured the resistance of the iac and got 10.4 ohms. Accordin to mitchelle all is well.
Then it said ignition timing, now call me stupid i was just curious to how this would affect idle? I'm going to check it soon just getting a timing light.
Is it say too much advance gives u higher idle?
Any hlp would be appreciated thx. Sry cars a 1990 5 liter stock but with everything removed that i could lol .
Also note checked tps and within the specified range.
Ze2222 is offline
Old 08-07-2009, 03:20 PM
mattdel
mattdel's Avatar
too far of an advance would cause a high idle in a carb'd car, yes, but our cars have computers that are supposed to compensate for it. have you visually checked that the plate inside the TB is closing all the way?
mattdel is offline
Tony71502
Tony71502's Avatar
Too far advanced timing = detonation. Too far retarded = no combustion. Has your motor ever been pulled out or has the cam been changed?
Tony71502 is offline
Old 08-08-2009, 02:07 AM
Ze2222
Ze2222's Avatar
not that i know of no. hmmm k i'll look elsewhere for my idle problem thx.
Ze2222 is offline
Old 08-08-2009, 11:24 AM
malo012000
malo012000's Avatar
could be the IAC need cleaning or replaceing
malo012000 is offline
Old 08-08-2009, 11:51 AM
john89 5.0
john89 5.0's Avatar
try cleaning you IAC. my car had a similar problem, it would idle at 1200 and thats helped it out
john89 5.0 is offline
Old 08-08-2009, 02:29 PM
Ze2222
Ze2222's Avatar
brand new iac. I'm going to go over again to see if i have a vaccum leak god damn frustrating idle lol. thx for the ideas anyways guys.
Ze2222 is offline
4cylinderplus2
10-09-2020 07:45 PM
TCStangerv6
10-11-2015 05:57 PM
svfetter
10-05-2015 11:39 AM
69Volunteer
09-30-2015 10:39 AM
MacSerio
09-27-2015 01:05 PM
Quick Reply: Idle problem. Just a question.
