Power loss, hesitatation, sputter, chug
#71
OK, so I plugged in the jumper wire ((First, paper clip, then I used an 18 gauge wire))
I tried both holes on the STI. When I used the paper clip, sparks sorted flew, but stopped rather quickly. When I did a KOEO/KOER test = the CEL stays on at a constant, and doesn't blink.
Not only do I suck at this ridiculously straight forward sh**, but now my CEL won't shut off... ACTUALLY, as I'm writing this post, I realized I disconnected the negative on the battery, and never hooked it back up, to see if the CEL turned off....
#73
I'm annoyed, my CEL won't turn off now, it wasn't on before...
I used 3 methods:
Over the counter; digital display, Scanner
Over the counter; tone & STO Light, Scanner
And the one mentioned before, which I think caused the CEL to stay on.
I used 3 methods:
#76
what is the code retrieved that is turning the light on?? or can you not blink a code out?? are you sure you didn't touch the wrong wires together?? if you did it may have shorted something in the ecu
#77
or other thing is you may have a hard failure that immidiately is logged , turning the light on, for example, until I bought a egr simulator, no matter how many times I cleared codes the light would stay on and everytime I pulled codes a egr code was there, after simulator install, code and light off!! this is just an example not a attempt to direct you to "this is your prob"
#78
THIS IS WHAT HAPPENED:
I couldn't get any codes, and I haven't gotten any codes yet.
First method, the one from your website, I hooked up the jumper wire into the wiper motor by accident. small sparks-almost nothing. I'm an idiot. Never got it into test mode. But, I did get the CEL to stay on. haha
Over the counter; digital display, Scanner = just reads 000, and won't go into test mode
Over the counter; tone & STO Light, Scanner = STO light stays on, and doesn't go into test mode.
It did run like sh** again, only when I gave the car gas. THEN, it went away...
So, I shorted something then. Well, how do I figure that one out?
#79
i know most will recommend you to do the DIY tests, but i really think this is bang for your buck.
http://www.amazon.com/Equus-3145-For...788707-8240433
I have one myself and it's been very handy. To each his own
#80
I don't know wtf is going on with my car. It seems fine.
