injector size vs. rear wheel horsepower question
Old 08-10-2009, 02:17 AM
94ford5liter
94ford5liter's Avatar
Default injector size vs. rear wheel horsepower question
When going to larger injectors I was just wondering what the increments for each set are. I know 24lb injectors are good to about 350rwhp. What about 30lb,36lb,42lb, etc? Does the limit increase about 50rwhp per 6 pounds more on each injector you have? Plans for a supercharger are not far off, so wanted to figure out what size injector I should use so I have room to grow.
94ford5liter is offline
Old 08-10-2009, 03:52 AM
luckythirteen13
luckythirteen13's Avatar
if your going sc, run 42s. the 42s will support enough hp to split your block.
its hard to say for certain what the hp rating of each injector because there are a few variables such as the fuel pressure you run and the duty cycle
luckythirteen13 is offline
Old 08-10-2009, 08:31 AM
Tony71502
Tony71502's Avatar
Right on, duty cycle = what % of the cylinder's compression stroke the injector is spraying fuel in.
If the injectors are not big enough they have to spray fuel the entire stroke (100% duty cycle) and that may not be enough fuel if they are undersized injectors. That's the basis for selection, basically. Not horsepower.
Tony71502 is offline
Old 08-10-2009, 08:33 AM
disposablehero27
disposablehero27's Avatar
www.rpmoutlet.com shows what each injector is rated at per each set. just look up injectors as if you were gunna buy them. shows how much they are rated to.
disposablehero27 is offline
Old 08-10-2009, 01:12 PM
94ford5liter
Well my other problem is, I can't find a mass air for 94-95 cobras that is calibrated above 36lbs. It seems like if I go above that, I would just have to make a lightning mass air work. I am going to be aiming for about 400rwhp, so I assume 36lb would be plenty.
Old 08-10-2009, 03:50 PM
NoGo95GT
NoGo95GT's Avatar
My car makes 400+rwhp and I am running 30lb injectors with an FMU and have no fuel problem. Plus I am running 15psi boost; 12-13 psi in the hot summer.
NoGo95GT is offline
Old 08-10-2009, 07:09 PM
94ford5liter
was 396 rwhp the 30lb injector limit on your car? Because I noticed in signature it says you ran out of fuel on the dyno at that level.
Old 08-10-2009, 07:23 PM
Liquid_02
Liquid_02's Avatar
If un-sure go bigger. You don't want to run any higher than an 80% duty cycle, your injectors will burn out and fail pre-maturely if you do.
Quick little equation you can do is:
HP X BSFC
#of Injectors X .80 (duty cycle)
So doing this... say you want 400hp, and your BSFC is .50 being NA
400 X .50
8 X .80
200
6.4
31.25lbs/hr
So for 400hp w/ 8 injectors you need 36lbs injectors to do it safely. I ran this equation many times before I bought my 42lbs injectors for my car. Keep in mind fuel pressure all plays a role as-well, this equation works normally for people running the industry standard 43.5lbs pressure.
Liquid_02 is offline
Old 08-10-2009, 07:26 PM
JD1969
Pro. B.S. caller outer
JD1969's Avatar
I am at about 400 rwhp, running 42's with a Vortech V2SQ. No computer tune, I just use a wideband, timing and fuel pressure. I am running a safe AF ratio. Did you call Pro M for a MAF? 94 Cobras are just 5.0's with a GT40 heads and intake, they really are nothing exotic.
JD1969 is offline
Old 08-10-2009, 08:15 PM
94ford5liter
I know they are not very different, but the computer is different, so apparently they need a different MAF compared to the standard gt. I suppose I could just try calling them. Most sites don't even carry a mass air unit for the 94-95 cobra though, and the sites I found that do only go up to 36lb. I guess because they made so few of them in comparison the the GTs.
Oh I see that on the PRO-M website I can get one for 42s because you select your vehicle type and just put in the injector size. Thanks JD . Didn't you have a camaro ss for a while?
Quick Reply: injector size vs. rear wheel horsepower question
