door hinge & bushing repair options
Old 08-12-2009, 06:24 PM
5pony0
5pony0's Avatar
Default door hinge & bushing repair options
Hey guys,
Had the lower hinge with the tension spring replaced on the driver side. New pins and bushings. Problem is, it still sags a bit when the door opens and doesn't quite line up when the door closes. With the door open a few inches, there is still some play when the door is lifted up. When open past half way there is no play.
My mechanic explained how the hole the bushing goes through (connected to the door) is elongated instead of being round. To try to give me another option instead of removing the hinge from the door and welding in a new one, he mentioned possibly getting a bigger pin bushing that will accomodate the size of the original hinge pin, but would be thicker to accomodate redrilling a larger hole to make it perfectly round to eliminate the play in the door hinge hole.
Anyone know of a kit or bushing that would work for this? or know of a different way to fix?
Thanks
1990 GT
5pony0 is offline
Old 08-12-2009, 07:08 PM
SonicBlueFiveSlow
SonicBlueFiveSlow's Avatar
Edit: Didn't read your post fully.
I'm not sure who makes a oversize bushing kit.
SonicBlueFiveSlow is offline
Old 08-12-2009, 08:41 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
have a new hinge installed don't let your mech monkey rig it, keep him away from ruining your fox with that backyard idea
mjr46 is offline
Old 08-13-2009, 08:30 AM
87notch408
87notch408's Avatar
Yeah X2 on not letting your mechanic mickey mouse it. Its more work to weld in new hinges but worth it.
On a side note did you (or he) attempt to adjust the striker? I replaced my pins and bushings along with the strikers a few months ago and had to play with the strikers a bit to get everything lined up correctly.
87notch408 is offline
Old 08-13-2009, 01:34 PM
ITALIANO66669
ITALIANO66669's Avatar
just to let you know 50resto has the pin kits with over sized bushings.im trying to decide if i need the oversized bushings or not myself.latemodelrestoration.com try them out.
ITALIANO66669 is offline
Old 08-13-2009, 02:47 PM
5pony0
5pony0's Avatar
I couldn't find it there...do you have the link?
5pony0 is offline
Old 08-13-2009, 02:49 PM
5pony0
5pony0's Avatar
goin to the body shop to get an estimate...(sigh).
5pony0 is offline
Old 08-13-2009, 02:53 PM
5pony0
5pony0's Avatar
Default oversized bushing kit
found the link for oversized bushing...
http://www.latemodelrestoration.com/item/LRS-BP7R
5pony0 is offline
jerrytubes
10-23-2015 12:11 PM
b8checker
10-08-2015 12:55 PM
Explosive
10-02-2015 07:45 AM
ChampInSD
10-02-2015 04:55 AM
Quick Reply: door hinge & bushing repair options
