next step for performance
Old 08-13-2009, 10:12 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
since all are saying gears, so will I
mjr46 is offline
Old 08-14-2009, 11:37 PM
ctlazersplaya07
ctlazersplaya07's Avatar
Originally Posted by Milton
gears,suspension, and tires
so what type of suspension should i look into that would give me a better launch...while making my daily driving still comfortable?....because if i lower it and stiffen the car...it will make driving around town rougher on the car
ctlazersplaya07 is offline
Old 08-15-2009, 01:13 AM
luckythirteen13
luckythirteen13's Avatar
no reason to lower if you dont want. some upper and lower control arms will make it a new car
luckythirteen13 is offline
Old 08-15-2009, 01:41 AM
302army187
302army187's Avatar
control arms, shocks & struts, subframe connecters, drag springs.
302army187 is offline
Old 08-15-2009, 11:56 AM
ctlazersplaya07
so all these things will make it more comfortable of a ride will still giving me a better launch?
i also want to lower the car a little bit to get rid of the large wheel wells......would eibach springs be good enough if i did the shocks and struts and control arms and sway bars....i want it to still be a smooth, not bumpy ride
Old 08-15-2009, 05:39 PM
NoGo95GT
NoGo95GT's Avatar
I'd get gears. For about $500 installed they will really wake up your car. Also, get a timing light and bump up your initial timing from the stock 10 degree to about 14-15 degrees. The car will feel much crisper. You can get under-drive pulleys for about $100. They slow the accessory drive and reduce parasitic loss to free up a few more HP. Also, for headers you can get a pair of Summit brand unequal length shorty headers for $99.95. I bought some for my stock Mustang and for $100 they were worth it. The only problem is you have to bend the stock EGR tube and the #4 plug wire is a pain to fit, but still worth the quick $100. Also, are you manual or auto. If manual I would get a short throw shifter. They stock one is junk. If you are an auto, I would get a transmission cooler and shift kit.
NoGo95GT is offline
Old 08-15-2009, 09:45 PM
ctlazersplaya07
nope i drive a manual...and i was thinking of going with a short throw a while ago but never did....i liked the UPR blu thunder short throw...should i look at a different one or is that one a good choice?
Old 08-15-2009, 10:24 PM
NoGo95GT
NoGo95GT's Avatar
Haven't really heard anything bad about the UPR. I think it's a Steeda knock-off. Apparently, the best one out there is the MGW shifter. I have one, just haven't installed it yet. My two picks would be either the Steeda Tri-Ax or the MGW. I think they are both around $180 too.
NoGo95GT is offline
Old 08-16-2009, 09:08 PM
ctlazersplaya07
what would people recommend for a type of suspension for the car to get rid of the wheel wells and give it a good setup for launches while not being too expensive? and by too expensive i mean like...under 1000 after install
firehorse02
11-16-2015 11:28 AM
Dokilar
15
10-16-2015 08:13 PM
ChampInSD
10-02-2015 04:55 AM
Boostaddict
Lethal Performance
10-01-2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
10-01-2015 08:57 AM
Quick Reply: next step for performance
