lager capacity fuel tank
does anyone know of a larger capacity fuel tank? other than the fuel cell offered by fuel safe in the steeda catalog becuase lets face it i definitly dont have 2k to spen on a fuel tank. haha. thanks in advance.
Unfortunatly, your choices are pretty limited. There are a couple of companies that make an aftermarket tank. The problem is the spare tire well. The tank has that odd shape to make room for the spare tire. If you flatten out the trunk floor, then you can extend the tank upward to fill in that space. Otherwise, the only place to go is down. You may not want to lose ground clearance.
The Fuel Safe cell 110A is listed as a 22 gallon cell. Unfortunatly, it's filled with foam, a ballder, collector, and collector valves. I can only get 18 gallons in mine.
There's another version of the Fuel Safe, SA110C. 20 gal. It's plastic, and not alum. It has a bladder and foam. Not sure about the collector. It's a bit cheaper at about $1,300. But I would suspect that it doesn't really hold 20 gal. Not sure it's worth it for just 2-3 gallons.
thanks for your replys. i want a bigger tank because im putting in a 331 stroker with a blower and me and my friends do runs outta town and a larger tank would have been nice. as for better mpg, id rather have more power haha.
