stage two idle problem
Old 08-16-2009, 05:44 PM
dirtjumper250
dirtjumper250's Avatar
Default stage two idle problem
dirtjumper250: @mustangforums.com Hello! Hi I am new here and just had a question on a couple of Things. I just built a new 306 with afr 185s trick flow track heat upper 75mm throttle body and meter. I also have a trick flow stage 2 cam. The car idles fine on cold start but will start to idle high after it gets hot. Over 1500 rpm. The normals have been done but has not helped. also why do factory throttle bodies have a hole in the throttle plate and aftermarkets do not from 2 mins 33 secs ago
dirtjumper250 is offline
bjdutch2005
03-24-2017 03:38 AM
2007StangV6
01-28-2016 06:09 PM
96stang3.8
09-10-2015 06:42 AM
Webster454
09-07-2015 04:59 AM
Quick Reply: stage two idle problem
