93 5.0 BOGGING DOWN AT FULL THROTTLE
Old 04-30-2008, 10:25 AM
Badnezz
Badnezz's Avatar
Default RE: 93 5.0 BOGGING DOWN AT FULL THROTTLE
i have a Vortech S-trim supercharger, with 4-10's, and everything else is stock what should i get next fuel pump or injectors right now i drive it 3 or 4 time a week. When i punich it it bag down. i have new plugs, wire, all that stuff whats the problem.
Badnezz is offline
Old 04-30-2008, 02:18 PM
brentloftis
brentloftis's Avatar
The post was started7/7/2005 8:34:40 PMand last updated8/19/2005 8:37:57 PM, you should start a new post if you are having a problem.
brentloftis is offline
Old 04-30-2008, 03:27 PM
Badnezz
Badnezz's Avatar
HUH
Badnezz is offline
Old 04-30-2008, 03:40 PM
brentloftis
I was saying that the post you replied to was a few years old. You should create a new post with your issue(s)
Regardless, your super charged with the stock pump and injectors? Sounds like fuel cut out to me.
Old 06-04-2013, 07:48 PM
95-5.0's Avatar
Talking I had the same problem
Originally Posted by Bob63
hello., everyone, Just put my 93,5.0 auto, vert on the road. It has 70,000 miles, I have replaced the plugs,and cap/rotor. It starts well, and idles fine. Here is the problem, upon accelleration, if you push the pedal down too far she starts to bog down, and RPMs fall off..... ease up on the pedal,away she goes again, as long as you accelerate slow it will go faster then you need to go, BUT punch it , she bogs BIG TIME..Any advise whould be appreciated!! Thanks fellows, Bob
i had the same problem expect all i did was unplug my air intake temp sensor and it ran great. i replaced it a day later and havent had a problem since
https://mustangforums.com/forum/imag...con_banana.gif
95-5.0 is offline
Old 02-15-2021, 02:15 PM
Lowpt
Lowpt's Avatar
Tps is the issue mines was doing the exact same thing turn your ideal screw out until it barely touched the plate and the adjust the tps to we're the rpm is sitting below 1000 at ideal not on 1000 but below 1000
Lowpt is offline
JDWalton
24
04-21-2007 06:34 PM
^iLLuSiOn^
12-28-2006 04:51 AM
87GT006
09-17-2006 12:45 PM
philly3384
04-12-2005 02:01 AM
BlueDemon
11-23-2004 04:34 PM
Quick Reply: 93 5.0 BOGGING DOWN AT FULL THROTTLE
