delete spoiler
there no type of plugs i can just stick in them. the screws from mine keep coming loose and making it rattle. waters also geting under it and leaving a streem of dirt down the back of my car., i could careless for it also.
yes they do make plugs for the holes but im not sure where you get them.but id just either get a new wing or fix the problem of them coming loose.im assuming your cars a hatch back and they look horrible without wings.
If you do manage to make/find a plug for the holes... you still will have to seal it to make it water tight. It'll look like a real hack job...
The right way to do it is to weld the holes shut. Or as stated find a spoiler where the threads arent stripped out.
If you do go for a new/different spoiler. Plan on getting the same one as you have now. Different style wings (GT, LX) have different bolt patterns.
i dnt mind the looks of it off, the roads around here are bumpy as ****. theres no type of rubber plug i can jus stick in the holes.
is there soposed to be a washer or somethingbetween the spoiler and the car , it doesnt seem to sit right i think thats why its comen loose all the time. but if i cant plug it what can i use to water doesnt get through or it and keep things tight
