Idle issue on startup
Old 08-19-2009, 09:52 PM
sim37
sim37's Avatar
Default Idle issue on startup
94 Mustang GT 5.0L
Good evening all, have a new problem.
I posted earlier about a vacuum line I could not find the end to. Well I managed to get it on and also replaced the vacuum line which controls my a/c vents.
Now when I start it up for a couple of seconds the idle bounces between 1200-800. It settles down and usually the first time I try to get going the car will stall. After I have driven for about a minute it idles normally and does not seem to have any issues.
Any input is appreciated.
sim37 is offline
Old 08-20-2009, 12:16 AM
sim37
sim37's Avatar
A little more info on the matter.
Also when I shift into reverse or drive it will drop the rpms and have a tendency to stall until I get moving. From a dead stop after a start it does this.
sim37 is offline
Old 08-20-2009, 12:35 AM
redemption
redemption's Avatar
couldnt be anything, busted o2 sensors, IAc is dirty
throttle is dirty
maf is dirty
vacuum leaks
or rarly ACT is dirty
redemption is offline
Old 08-20-2009, 02:06 AM
sim37
sim37's Avatar
And that's all typical of the drop in RPM when I change gears?
sim37 is offline
Old 08-20-2009, 02:09 AM
89gtwith3.55s
89gtwith3.55s's Avatar
have you installed a CAI? you could be running lean... i had that problem in the beginning i would start and it would idle rlly low bounce a bit then stall but only if the engine was cold
89gtwith3.55s is offline
Old 08-20-2009, 02:31 AM
sim37
sim37's Avatar
Yes I do have a BBK CAI. How would I go about checking the mixture?
sim37 is offline
Old 08-20-2009, 10:37 AM
89gtwith3.55s
check to see if your vacuum lines are intact and check the o2 sensors... i got mine tuned so i really cant help too much sorry =/
Old 08-20-2009, 01:26 PM
redemption
redemption's Avatar
no i meant for idling not changing gears, o2 sensors will jack with you if ones broken or both, but before you buy parts do a koeo test and pull codes it will tel you what sensors are busted
2007StangV6
01-28-2016 06:09 PM
stangin1996gt
09-21-2015 11:01 AM
LivingInThePast
09-16-2015 12:20 PM
Scottyboy187
SVT Forums
09-13-2015 10:23 PM
Emblazoned
09-03-2015 10:45 PM
Quick Reply: Idle issue on startup
