driver window wont roll up
My car had the same problem, the motor is shot. Hence the voltage drop when the switch is engaged. I just replaced the motor in my coupe last week takes 30 minutes or so start to finish. Look for 3 bolts (10mm) above the speaker about 2/3 the way up the door. Remove the three bolts. Then take out your speaker. The window motor will take some effort to remove but put your arm through the speaker hole and remove motor. Window motors are 40 buck at auto zone.
