How to tell if control arm is bad?
Old 08-22-2009, 07:08 PM
turbosha
turbosha's Avatar
yeah , i didnt think of the ball joints.
turbosha is offline
Old 08-22-2009, 07:52 PM
Jfsram
Jfsram's Avatar
A balanced tire can still shake a car. Remember see saws, as a kid.
Sidewall imperfections, flat spots, bent rims etc, can all still be balanced and shake a car. Try swapping a known good set onto your car.
Jfsram is offline
Old 08-22-2009, 07:53 PM
bbbngowc
bbbngowc's Avatar
Originally Posted by mattdel
check the balljoints? jack under the front lower control arms, shake the tire up & down and side to side, then take a big pry bar and pry the tire up.
Haven't tried that. I'll do this tomorrow. So I'm just going to jack the car off the ground freeing up the tires, then shake them back and forth and side to side?
bbbngowc is offline
Old 08-22-2009, 07:54 PM
bbbngowc
bbbngowc's Avatar
I had the four tires balanced twice. Well I at least took them to get balanced two times at two different locations. Just thinking that the first place didn't do a good enough job. But they were fine.
bbbngowc is offline
Old 08-22-2009, 08:50 PM
luckythirteen13
luckythirteen13's Avatar
has this problem slowly gotten worse over time or did it just start one day?
luckythirteen13 is offline
Old 08-22-2009, 09:18 PM
bbbngowc
bbbngowc's Avatar
Slowly gotten worse over time.
Started changing parts; Rotors, brakes, rack, spark plugs, wires, studs ... and the vibrations are getting worse.
I hate driving the car now because of it. I'm ready to sell the car, but I would like to at least get this fixed.
bbbngowc is offline
Old 08-22-2009, 09:29 PM
Tony71502
Tony71502's Avatar
So, have you checked your ball joints?
Tony71502 is offline
Old 08-23-2009, 02:24 AM
luckythirteen13
if its slowly getting worse over time i would look at parts that age over time like rubber parts
Old 08-23-2009, 03:00 PM
bbbngowc
bbbngowc's Avatar
Just checked and I'm getting a tiny knocking when rocking from side to side. Nothing major. Does this sound like a bad ball joint?
bbbngowc is offline
Old 08-23-2009, 03:37 PM
mattdel
mattdel's Avatar
side to side could be a tie rod or a ball joint. have someone else shake it while you visually look for play.
mattdel is offline
Quick Reply: How to tell if control arm is bad?
