car cutting off
car cutting off
I have a 94 gt that keeps cutting off when i push the clutch in. like when i go around a turn i push the clutch in to downshift and the car will just drop rpms until it cuts off. i have an a9l computer and a sct chip for the car. the maf is clean and no vaccum leaks. whats else?
it doesn't do it just in corning it can be when i come to a stop light or something to. i down shifted to take a off ramp tonight and when i pushed the clutch in the car surged down and cut off. ikt seems to be worse when it is wet or after the rain. almost the moisture in the air throws the car off
and i don;t get any codes. the comp. swap was supposed to stop this issue and it did for a while and then it started acting up again. last time i had this problem the tuner adjusted the throttle blade up a little and took care of it but i doubt the blade adj. moved again it is tight and has a locknut
did you repin the harness and everything when you did your swap? if so that had to be a pain to switch back huh
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
