need some help with intakes
Hi I need some Intake help. Right now I an running a trick flow track heat intake. My car is running high 7.80s in the 1/8th. I have afr 185s, trick flow stage 2 cam, 24# injectors, 75mm all, and bored 30 over. I would like to get down to 7.50s and was wondering if anybody thinks the trickflow R series might get me there. I would take any suguestions. Thanks
Before you go swapping parts that have already been upgraded from stock theres alot of room where you can improve. Suspension being the first thing. Depending on how much you want to spend you can make some major improvements in your cars handling, 1/4, etc. Check out some subframe connectors, lower control arms, etc.
I have wiesco pro true pistons flat tops, bbk long tubes, x pipe. you know all the normals. My 60 ft times are low 160s and I also have alumnim drive shaft. But frt and rear suspension are all stock. Those times are with hoosier slicks
thank god for torque plates lol Your 60ft times are pretty good but I would definitely work on that rear suspension. And also, for the price of a nice U/L manifold you can buy a tubular front suspension and knock some decent weight off the front.
