High volume oil pump ???
08-23-2009, 11:43 AM
can i run 1 in a stock 5.0 foxbody with no problems or should i just got with stock
08-23-2009, 11:54 AM
D.R. THE PATHETIC DORK
no need for such in a mild street engine whose life lives below 6k
08-23-2009, 12:21 PM
agreed, there really is no reason for it. But if your in the process of changing it already you can go with it if you want to. I run a Miloden in my 93 GT, and would recommend it anyday.
08-23-2009, 08:43 PM
ok cause i bought a short block and it came with it
08-23-2009, 08:49 PM
It's fine in a stock engine, but like stated, not needed. Just make sure you have good oil return and the pump pickup is located correctly.
08-24-2009, 02:50 PM
ok thanx i just wanted to double check
10-26-2015 05:01 PM
Scottyboy187
SVT Forums
09-13-2015 10:23 PM
Pyrate Dave
09-10-2015 07:30 PM
iamgobono
09-03-2015 12:37 PM
302,
50,
body,
change,
fox,
high,
loses,
motor,
mustang,
oil,
older,
pressure,
pump,
pumps,
supercharged,
volume
