strut problem
Old 08-26-2009, 02:25 AM
rmodel65
Yukon Cornelius
rmodel65's Avatar
KYB is a good all around strut, the mustangs is a little easier than most car when changing the strut since the spring isnt attached to it :P
rmodel65 is offline
Old 08-26-2009, 10:28 AM
ctlazersplaya07
ctlazersplaya07's Avatar
okay...so as i was looking at it more closely in the daylight....it seemed like the noise was coming from the ball joint...i had this problem with my last car....the ****subishi...and the guy that fixed it ran me about 600 bucks...did i get fooled or is that the going rate to replace a ball joint? i would put some grease into the joint but it does not have a grease fitting....so what should i do now?
ctlazersplaya07 is offline
Old 08-26-2009, 12:17 PM
kennebellgt
kennebellgt's Avatar
Jack the car up in the air then put it on jack stands then take the jack and position it underneath the A-arm and jack it up just until the car barely starts to go up then grab the rim/tire and pull out on the bottom and push in on the top go back and fourth, (you want to see if there is any movement with trying to wobble the wheel in and out) you want to see if there is any slop to it, if there is any slop at all replace the ball joint, if its bad your best bet would be to take your A-arm off go get a new ball joint and take it to a shop to have the new one pressed in that would be a very cheap route.
kennebellgt is offline
Old 08-26-2009, 02:13 PM
ctlazersplaya07
sorry to tell you guys....but after all my predictions...my mechanic told me i was wrong....it was a stupid tie rod....so he is replacing it for 100 bucks....that includes the part and labor...so i feel like that is a pretty god deal....unless you guys can tell me otherwise
Old 08-26-2009, 04:11 PM
mattdel
mattdel's Avatar
never seen a tie rod make noise.
mattdel is offline
Old 08-26-2009, 04:56 PM
ctlazersplaya07
yea...every time i turn the wheel....there is a little creeking noise....and when i hit a bump while turning....the noise is louder than normal. so yea...gonna get the tie rod fixed tomorrow....i will let you know if the noise goes away so we can learn if a tie rod makes that noise or not
67STANGX2
09-24-2015 12:29 PM
warwickbass
09-20-2015 04:51 PM
GentleBen
09-11-2015 05:34 AM
robjh22
Suspension
09-08-2015 12:47 PM
Quick Reply: strut problem
