convertible top problem 92
i was putting the top down a few days ago and in the middle of going down it just shut off. The motor does work i hooked it up to another convertible and it worked. I replaced the relays and fuse. When i press the up/down switch i can hear the relays clicking.ANY IDEAS????? the voltage to and from the switch is fine.
checked the power going into the pump and its normal, and no when i push the switch you can just hear the relays clicking , the motor doesnt make any sounds and i know its not the motor cuz it works
make sure you have no loose grounds, theres not much else it could be and you made sure your getting the right amount of voltage to the motor?
Calizic
08-28-2015 01:46 PM
Mustang Sally72
08-11-2015 07:54 AM
