Stang will not turn over! KILLS ALL POWER
Hey guys and gals, I am new to this forum, however I am not new to the FOX Mustang. I have an ignition problem that is most baffling. New battery, new starter, new ignition solenoid. I turn the key and get all the chimes and lights I should. As soon as I attempt to start my baby I get a soft click and all power dies. When I remove the key I get nothing and I have to disconnect the battery and reconnect it to try again. Needless to say I have have the batt., starter, cables tested. Any clues, am I missing something simple. Please help. This car is stating to aggrivate my wife.
Thanks,
Rob
Thanks,
Rob
my thoughts
Thats what I was thinkin, I have tried tearing into the wiring harness and isolating it, I am an electrician by trade, so you'd think it would be easy. Anywhere in particular sound like a suspect. Ignition switch in the column, harness links in through the firewall, anything???
so, i disconnected the starter cable from the ignition solenoid and fluked it. i got 0.1 ohms to ground. bad! i took the cable off the starter and fluked the starter and i get 0.1 ohms to ground. how! whats the deal. im pretty sure it shouldnt read a ground on the connection point. its a new starter too
