Last edit by: IB Advertising
Browse all: Ford Mustang Powertrain Guides
- Ford Mustang V6 2005-2014: Why is My Power Steering Reservoir Leaking Foam?
Guide to diagnose trouble and recommended solutions.
Milky/foamy power steering fluid
I recently changed my rack and pinion and now the power steering fluid is a pink milky/foamy fluid. The car also makes a horrid noise when turning.
What's the solution?
If it still does it after a while you have a leak somewhere allowing air to enter the system. That happened to me and it felt like I had manual steering again. First pump went out causing my thousands of dollars new front suspension.
