Differential Carrier Shims.
Hi guys,
I am in the process of building a rear end for my car. I took the old stuff out and I am a little confused. I thought the carrier shims would be multiple plates, but upon removal I did not see many shims. All that I saw was the bearing races and the single plates. Is this the shim I have on top of the race(see attached pic)? Please excuse me if this is a dumb question.
Thanks.
Thanks.
I don't know, I just picked up the rear end, and know nothing about it. Everything is getting replaced. I'm not too concerned how many shims are in there, I am just wondering if the piece in my pic is the shim. I was just expecting the shims to look like a series of plates like this:
the one you have picture are factory shims, if you are installing new gears in the process and expecially if they are of a different ratio, you may or may not use the factory shims, with some ford racing gears you can get away with reusing the factory shims as long as the correct pinion shim is used
Boostaddict
2.3L Eco-Boost Tech
11-24-2015 06:11 AM
KingRando
10-02-2015 08:06 AM
09-16-2015 07:53 PM
