How difficult is a 5 lug conversion?
Old 09-04-2009, 11:03 AM
sixtyninestang
sixtyninestang's Avatar
I'm a bit confused when it comes to the front. The rotors are separate from the hubs unlike the current setup, so I'll need new hubs to attach the rotors to. I haven't seen that mentioned yet. Is that because everyone is doing the swap from an SN95 and getting the parts from that? I was thinking of doing the swap exactly as you described it; I'm not ready to go with a rear disc setup.
sixtyninestang is offline
Old 09-04-2009, 11:21 AM
primetime5.0
primetime5.0's Avatar
there is 2 ways to swap the front.. rotors from an svo will work but the hub will stick thru the wheels on most setups. If you get 94-95 stuff you get the better brakes, better steering geometry, less weight on the front end
primetime5.0 is offline
HRnB
GT350 S550 Tech
12-18-2015 09:35 AM
11-10-2015 11:39 AM
10-07-2015 07:02 PM
Quick Reply: How difficult is a 5 lug conversion?
