Leaking Doors on Sunroofed Hatch
Old 09-04-2009, 09:51 PM
Stangs4me
Stangs4me's Avatar
Default Leaking Doors on Sunroofed Hatch
I just got a '93 LX with a sunroof and in rain, I get a few drips from the top of both of the door. The rubber lining around the doors is in perfect condition. Where do I go from here?
Stangs4me is offline
Old 09-04-2009, 09:53 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
even though the lining may look fine it may be compressed flat, I'd install a new seal
mjr46 is offline
Old 09-05-2009, 08:51 AM
ALMOST STOCK
ALMOST STOCK's Avatar
Here are a few places you get the door weather stripping if you decide to take that route.
http://www.foxresto.com/?p=vp&id=871
http://www.latemodelrestoration.com/
http://www.cjponyparts.com/weatherstrip/c/20200000/
ALMOST STOCK is offline
Old 09-05-2009, 10:03 AM
Dj_Seph
Dj_Seph's Avatar
That or his sunroof drains are clogged. I'd try that first.
Dj_Seph is offline
Old 09-05-2009, 10:48 AM
Stangs4me
Stangs4me's Avatar
The car's at my mechanic's shop right now but as soon as I get it back, I'll check it. One question though, how would clogged sunroof drains make the water come from above the door?
Old 09-05-2009, 01:24 PM
stang8689
stang8689's Avatar
well have someone spray water on it while ur inside and see where its coming in at u might have to bend the door frame some roll ur window down and bend it in a little
stang8689 is offline
Old 09-05-2009, 01:40 PM
Dj_Seph
Dj_Seph's Avatar
Actually when my sunroof drains were clogged, it leaked right inside near the door. The drains are at the corners of the sunroof.
Dj_Seph is offline
Old 09-05-2009, 04:19 PM
Stangs4me
Stangs4me's Avatar
So I checked the drains for the sunroof and they were flowing properly. Then I took some weatherstripping I had leftover from an Audi I parted out in my garage and put it in place of the old worn-out door weatherstripping and the car still leaked when I hosed it down. So then I bent in the tip of the driver's door a little with the window open and it seemed to fix the problem
Old 09-05-2009, 07:52 PM
mjr46
mjr46's Avatar
good job
mjr46 is offline
Old 09-06-2009, 01:12 PM
Stangs4me
Stangs4me's Avatar
Originally Posted by mjr46
good job
Thanks
Quick Reply: Leaking Doors on Sunroofed Hatch
