Ran a KOEO test, what do they mean?
Old 09-06-2009, 07:02 PM
86 5.0L
86 5.0L's Avatar
Default Ran a KOEO test, what do they mean?
for the KOEO I got a code 54, for Memory I got 18, 54, 63, and 32. what do they mean?
86 5.0L is offline
Old 09-07-2009, 03:07 AM
86 5.0L
86 5.0L's Avatar
bump?
86 5.0L is offline
Old 09-07-2009, 04:21 PM
86 5.0L
86 5.0L's Avatar
do I replace the ACT sensor to fix code 54?
86 5.0L is offline
Old 09-07-2009, 05:02 PM
AdderMk2
Banned
AdderMk2's Avatar
18: (C) IDM circuit failure or SPOUT circuit grounded (R) SPOUT circuit open or spark angle word failure
32: (O/R) EVP circuit below minimum voltage of 0.24v (C) EVP circuit has intermittently failed below minimum voltage of 0.24v
54: (O/C) ACT sensor signal is greater than the self test maximum of 4.6 volts
63: (O) TPS circuit below minimum voltage 0.6V (C) PS circuit has intermittently failed below minimum 0.6v
AdderMk2 is offline
Old 09-07-2009, 05:07 PM
86 5.0L
86 5.0L's Avatar
if they're in CM, that means it happened at one point. I cleared the codes, but I havent droven around, if they pop up again then 18, 63, and 32 are problems?
86 5.0L is offline
Old 09-07-2009, 05:09 PM
AdderMk2
Banned
AdderMk2's Avatar
O means it failed during KOEO (EVP on an KOEO isnt anything to worry about)
R means it failed KOER These are important...
C means it happend at some point, but isn't happening now.
AdderMk2 is offline
Old 09-07-2009, 05:11 PM
86 5.0L
86 5.0L's Avatar
is there a way to test the ACT sensor further? or just replace it?
EDIT: found out how http://fordfuelinjection.com/?p=29
86 5.0L is offline
TCStangerv6
10-11-2015 05:57 PM
Dathan
10-05-2015 05:52 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
Florida Regional Chapter
09-30-2015 08:04 PM
GT350 S550 Tech
09-29-2015 03:29 PM
Quick Reply: Ran a KOEO test, what do they mean?
