1990 gt dash wiring harness
Old 09-07-2009, 07:22 PM
bigt8156
bigt8156's Avatar
Default 1990 gt dash wiring harness
Hey Guys I have a question. I have to replace the dash wiring harness on my mustang. I got one out of a 93 lx I need to know if they are year specific or can I use this one. Or do I need to get one out of a gt.
bigt8156 is offline
Old 09-07-2009, 09:46 PM
stang8689
stang8689's Avatar
i would try to get one out of any 93 with same engine but you should atleast get one out of a 90-93 cause of air bag and guage cluster is different
stang8689 is offline
Old 11-21-2009, 09:07 PM
johndeeregreen
johndeeregreen's Avatar
go to very useful.com and look at the harness schematics you can use the 93 harness its just that some 91 harnesses are specific and you can't mix 91 and prior with 91 and later
johndeeregreen is offline
Old 11-21-2009, 10:33 PM
ALMOST STOCK
ALMOST STOCK's Avatar
Hopefully this helps.
87-88 harness Non Calif, SD will fit 87-89
88 Cali-89, MAF will fit 87-89
90 MAF, 90 only
91-92 MAF 91-92 only
93 MAF, 93 only.
ALMOST STOCK is offline
Old 11-22-2009, 12:10 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
I believe one of the main differences is the location of the fuel pump relay changed from under the seat to out under the hood, so harness is different
mjr46 is offline
Old 11-22-2009, 11:03 AM
ALMOST STOCK
Exactly.
Some other differences also.
87-88 has no airbag connectors, no mass air connector
89 has no airbag connectors, has a mass air connector.
90 has mass air, airbags, and you need to look where the harness connects to the headlight/alternator harness, has a grays and black connector.
91-92 has mass air, airbag, only one relay by the mass air connector (A/C wide open throttle), and has brown headlight / alternator plugs.
92-93 has mass air, airbag, TWO relays by the mass air plug (A/C wide open throttle and the fuel pump relay), and has the same headlight / alternator plugs (only difference being the fuel pump relay).
jwog666
12-27-2021 08:09 PM
Urambo Tauro
10-05-2015 09:37 PM
Matt's 95 Stang
10-05-2015 07:16 AM
breaking
10-02-2015 01:27 PM
Quick Reply: 1990 gt dash wiring harness
