Is the 302 a good weapon of choice?
While a "stock" 5.0 may not be anything special, especially in today's society, there is one thing it has going for it: TORQUE! And it makes a lot of this at a low, low rpm. You will not have to wind the car up to get moving. 4000rpm and you're done. Also, simple mods can really make a 5.0 come alive: 3.73 gears, bumped up timing, K&N, and exhaust and you have a 13 second car, if you can drive
some guys run the stock T-5 if it's manual, but you have to know how to drive and select a clutch and tire that won't shock load the trans. I prefer a beefier trans that can be flogged myself, since it gives you some error room. AdderMk2 would know what to select better than I though, he's got many passes on the stock T-5 with a 347. Suspension, you're gonna want to look at control arms/bushings, and possibly a watts link or panhard rod. Make sure to check out the rear end too, a stock worn out LSD diff won't last long. Then there's subframe connectors at least for the chassis, depending on how much power you build you may or may not want/need a roll cage(if you go fast enough NHRA requires a bar, then a cage etc.).
Galactic
04-29-2019 02:56 PM
mungodrums
10-07-2015 04:01 AM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
