Speedo Gear ??
Old 11-16-2003, 10:19 PM
89 GT
89 GT's Avatar
Default Speedo Gear ??
Have 1982 SROD, does anyone know how many driven teeth this thing has 6 or 7. I counted 5 full teeh with the start of one tooth and the end of another tooth. Trying to figure out which speedo gear to buy.</P>
89 GT</P>
89 GT is offline
Old 11-16-2003, 10:36 PM
vfast
I ♥ Acer
vfast's Avatar
what transmission?
Manual Transmissions with 7 Tooth Drive Gear
* 1983-1989 T-5 OEM
* Pre 1993 T-5 Aftermarket
* 1996-1998 Cobra T-45 OEM
* All Tremec Transmissions
2.73 Gear Ratio / Maroon 16 Speedo Gear
3.08 Gear Ratio / Yellow 18 Speedo Gear
3.27 Gear Ratio / Pink 19 Speedo Gear
3.55 Gear Ratio / Black 20 Speedo Gear
3.73 Gear Ratio / Red 21 Speedo Gear
4.10 Gear Ratio / White 23 Speedo Gear
Manual Transmissions with 8 Tooth Drive Gear
* 1990-1995 T-5 OEM
* 1996-1998 T-45 OEM Except Cobra
2.73 Gear Ratio / Yellow 18 Speedo Gear
3.08 Gear Ratio / Black 20 Speedo Gear
3.27 Gear Ratio / Red 21 Speedo Gear
3.55 Gear Ratio / White 23 Speedo Gear
3.73 Gear Ratio / White 23 Speedo Gear
Automatic Transmissions with 7 Tooth Drive Gear
* 1983-1989 Automatic Transmissions
2.73 Gear Ratio / Blue 16 Speedo Gear
3.08 Gear Ratio / Gray 18 Speedo Gear
3.27 Gear Ratio / Tan 19 Speedo Gear
3.55 Gear Ratio / Orange 20 Speedo Gear
3.73 Gear Ratio / Purple 21 Speedo Gear
Automatic Transmissions with 8 Tooth Drive Gear
* 1990-1998 Automatic Transmissions
2.73 Gear Ratio / Gray 18 Speedo Gear
3.08 Gear Ratio / Orange 20 Speedo Gear
3.27 Gear Ratio / Purple 21 Speedo Gear
<img border="0" src=smileys/smiley14.gif border="0">
vfast is offline
Old 11-16-2003, 11:20 PM
89 GT
89 GT's Avatar
Thanks for such a fast reply.</P>
The trans is a 4 speed manual they came in 79-83 Mustang GT's they are called SROD's. Mid 1983 Ford switched to the T5. The speedo gear is the same in the SROD and T5. The SVO cata states 16 for a 6 tooth drive gear and 19 (Pink) for a 7 tooh drive gear. My rear end has 3.27 gears.</P>
Any takers on what this SROD has 6 or 7?</P>
Itoasted 3rd and 4th gear in my 89 AOD so I have this SROD trans (free) so I'm swapping it in for now. </P>
89 GT</P>
</P>
89 GT is offline
Thunderball
15
11-22-2015 11:49 PM
Bokeo
10-10-2015 08:28 PM
KingRando
10-02-2015 08:06 AM
uedlose
The Racers Bench
10-01-2015 08:31 PM
junior04
09-28-2015 10:53 AM
Quick Reply: Speedo Gear ??
