Converting to manual steering?
Old 05-22-2012, 08:25 PM
mustangsnake93
mustangsnake93's Avatar
......turns out that the rack should measure 45" end to end, and the one i have is only
43 3/4". So i ordered 6" tie rods instead witch will give me an extra 1" to screw onto. Then tonight i get home to see my new off set bushings have arrived and the damn holes in the bushings are 3/8", the pins that came with the bushings are 1/2" and the old bolt measures 1/2"......do i drill out the bushings or what???????
mustangsnake93 is offline
Old 05-25-2012, 08:19 PM
mustangsnake93
had to drill out the bushings to 1/2", got it all back together realined and it drives great. My front tires are 10" wide and I have no problem turning at low speeds, that was one thing i was worried about. Also had to replace the water pump due to the belt running on top instead of the bottom side when removeing the power steering pump.
Old 05-26-2012, 04:50 PM
Jay_Man
Jay_Man's Avatar
How much of a difference does swapping out for a manual rack make? I currently have no power steering with a "power steering" rack. I was considering putting the power steering pump back in because it is a bit difficult for cruising around town. Make jokes if you must haha.
Jay_Man is offline
Ken_in_d
04-15-2016 02:25 PM
GPR
12-16-2015 12:21 PM
stark777
09-21-2015 12:46 PM
rksnow1
09-14-2015 08:46 PM
wileec
09-11-2015 10:16 AM
Quick Reply: Converting to manual steering?
