Need info on a st of bolts (builders enter)
Need info on a set of bolts (builders enter)
One of my customers mailed me their camshaft thrust plate so I could countersink the bolt holes. He will be running a comp cams timing set that uses a torrington bearing.
The problem I have is that he sent me some cheap garbage philips head bolts... this simply will not do! I need to know what the thread size, pitch and length is of the stock camshaft thrust plate bolts.
Lets see who gets this one!
Assuming you're talking about a 5.0 HO block. I wish I had a micrometer here at the house, I have about 3 at the shop. I pulled one of the thrust plate bolts out of my 351w, should be the same. Measuring from the bottom of the head to the bottom of the thread is .70 inches, 1/4" thread. This is using a machinist's ruler.
folivier
Tennessee Regional Chapter
10-02-2015 05:32 AM
junior04
09-28-2015 10:53 AM
