keeps dying at idle...plz help
ok guys as some of you know, my car has been idling high and have a major vac leak. so i had take the upper intake off and fixed the vac lines under it, and checked the gaskets. now i have put it back together and add 24lb injectors with 24lb sample tube. the leak isnt as bad, but theres still a slight whistle that comes and goes. and my idle will stick at around 1500 and then go towards 900 and die everytime. i think when i hear the whistle the idle raises up itself, and when there is no whistle the idle goes to normal and dies. if i dont give it some throttle it will die out.
so if went from always idling around 1500 and never dying out, to idling high half the time and dying out the other half...im confused.
What could cause that?
