Hood problems
Old 09-23-2009, 03:07 PM
19stang88
19stang88's Avatar
Default Hood problems
So the other day i was changing my oil and when i finshed my hood wouldn't shut properly, no matter how hard i slammed the hood it would shut. It use to work properly and i would bearly just slam it to shut it correctly. Is there something that I could do to fix this problem with out going to body shop?
19stang88 is offline
Old 09-23-2009, 03:09 PM
mattdel
mattdel's Avatar
very open ended question.. why wont it shut? is the body alignment off? is the latch not catching? is the hood catch broken?
we're not mind readers.
mattdel is offline
Old 09-23-2009, 03:23 PM
1ATony
Former Sponsor
1ATony's Avatar
Yah, If it's the front the hood latch may be stick closed if you still have it.
1ATony is offline
Old 09-23-2009, 09:37 PM
19stang88
19stang88's Avatar
I just took a look at it. The hood latch near the radiator, is there anyway i can test it to see if it is working properly?
Old 09-24-2009, 11:35 AM
mattdel
mattdel's Avatar
close it by hand and see if it stays closed. more than likely going to need a replacement.
http://www.latemodelrestoration.com/item/LRS-16700B
mattdel is offline
Old 09-24-2009, 12:26 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
Make sure the hood release cable is pushed in. Mine sticks and after pulling it I have to push it back in. You could have the same problem. But trying to slam it will only make things worse.
PRO50SC is offline
Old 09-24-2009, 03:25 PM
ALMOST STOCK
ALMOST STOCK's Avatar
Yep the infamous DBL post
ALMOST STOCK is offline
Old 09-24-2009, 03:35 PM
ALMOST STOCK
That was my first thought also!
2nd though is to make sure the 2 small bolts holding the latching mechanism aren't loose and the whole latch has slipped down and your unable lock the hood into place.
Old 09-25-2009, 01:34 PM
ramz28
ramz28's Avatar
get rid of it all and get hood pins and u will never had hood problems again. but yea go with those guys^ and check the cable. or like my old hood latch used to get stuck in the lock pos. and id have to pull the release again.
ramz28 is offline
Nick Oliver
10-17-2018 04:22 AM
StalkerGT
09-25-2015 02:41 PM
Pyrate Dave
09-10-2015 07:30 PM
96stang3.8
09-10-2015 06:42 AM
Art161
09-09-2015 10:33 AM
Quick Reply: Hood problems
