before I start her up after the mod in 1/2 hour
Old 09-23-2009, 03:47 PM
ibayter
ibayter's Avatar
Default before I start her up after the mod in 1/2 hour
ok guys, finally I am going to start her up, just one more thing before I do it, I have my motorcraft spark plugs, I read on this forum that many people with my set up (which is TF twisted edge and stage 2 cam upper and lower cobra intake, 70 mm TB, original injectors, MSD coil, dist. and 6 AL box) should I change the spark plugs to autolite 3924 ? what would happen if I leave the original motorcraft ?please let me know as soon as you can.
ibayter is offline
Old 09-23-2009, 04:04 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
you need to use what tf recommends the stock plugs for e7 heads are not correct, do not start it unil you put the proper plugs in
mjr46 is offline
Old 09-23-2009, 05:16 PM
ibayter
ibayter's Avatar
Default gap?
Ok thanks MJR Iam changing then now please what is the gap for the autolite? the same 45mm?
ibayter is offline
Old 09-23-2009, 05:18 PM
ibayter
ibayter's Avatar
please anybody could letme know ? I am anxious to hear her roaming? Ihave been waiting long time to do this set up!. Thanks,
IBM
ibayter is offline
Old 09-23-2009, 05:33 PM
mjr46
mjr46's Avatar
set them to stock spec
mjr46 is offline
mstahoo
SVT Forums
08-19-2021 09:15 PM
drfister
05-03-2018 10:38 PM
SterlingStunner
5.0L V8 Technical Discussions
09-04-2015 06:28 AM
Displ8cement
Texas Regional Chapter
08-13-2015 12:37 PM
cema93
08-10-2015 09:35 PM
Quick Reply: before I start her up after the mod in 1/2 hour
