Overheating problems, help pleaze!!
Old 09-28-2009, 10:29 AM
ramz28
ramz28's Avatar
^lol not that stupid seen it done many times coming into the shop.
ramz28 is offline
Old 10-07-2009, 08:23 PM
BillzBoi
BillzBoi's Avatar
So this is the results. I did the pressure check, and it was leaking somewhere slowly, but i think it was through the machine itself. I changed the radiator anyway, and then I realized that the same thing was happening after I changed it, so I looked in the radiator and didnt see the antifreeze pumping, so that made me think its the waterpump, but I just replaced it a couple months ago. So I felt on the upper and lower hoses coming from the radiator, and felt no flows of anything, so tomorrow I'm gonna change the waterpump, but if it isn't that, do anyone have any suggestions of what it can be?? Pleaze help!!
THe car gets hot pretty fast. I drive down two blocks and its by the the H, hot, hot. I checked the oil and tailpipes for water or anything, but there's nothing there, so someone pleaze help me, THANKS!!
BillzBoi is offline
Old 10-09-2009, 10:39 AM
ramz28
ramz28's Avatar
how fast did the pressure drop? ive had a pressure tester leak as well. Theres not much to a cooling system. if your pump, hoses, radiator and thermostat is good. and you have no flow seems like you have clog some where. your going to have to flush the system. or your thermostat is in backwards.
ramz28 is offline
Old 10-09-2009, 09:53 PM
nota46
nota46's Avatar
i had the same problem and i changed all the things u did after i installed the thermostat i ran the car and realized it was my fan that was broken it never turned on at all
nota46 is offline
Old 10-09-2009, 10:56 PM
dreamer1uk
dreamer1uk's Avatar
Hi,
Like the above poster said, make sure your fan is working correctly. Did you flush the heater core too?
dreamer1uk is offline
mungodrums
09-29-2015 09:18 PM
stangin1996gt
09-21-2015 11:01 AM
yourmom6990
09-14-2015 10:52 PM
MusicCity615
09-12-2015 07:05 AM
96stang3.8
09-10-2015 06:42 AM
Quick Reply: Overheating problems, help pleaze!!
