What Size Push Rods
Old 09-30-2009, 08:51 PM
  #31
sgarrelts01
sgarrelts01's Avatar
The length of my push rods are 7.100 i kept forgetting i can't get a estimate of what others are using because they have roller stuff, which will be shorter then what i need.
sgarrelts01 is offline
Old 10-04-2009, 12:01 AM
  #32
sgarrelts01
Originally Posted by mjr46
to make it roller, there are two options...option 1 expensive 450.00 link bar retro fit lifters and roller cam.......option 2 reduced base circle cam and stock roller lifters and hardware and tap valley for spyder retainer, if interested in option 2 I have retro fit cam = comp thumpr cam .530/.515 lift but with the cam it still reccommends the retro expensive lifter = these
http://www.summitracing.com/parts/CCA-8931-16/
anyway I have cam and springs...175.00 for both if interested
For Option 2 will this kit work
http://www.summitracing.com/parts/CM...n/?prefilter=0
Just wondering because it comes with that retro kit, a cam and lifters. How do i tell if its a reduced base circle cam.
Old 10-04-2009, 10:08 AM
  #33
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
NO, THAT IS NOT A RETRO FIT KIT, that is a stock set up for a roller equipped block, a reduced base circle cam is obvious = small skinney core
mjr46 is offline
Old 10-04-2009, 02:31 PM
  #34
sgarrelts01
http://www.summitracing.com/parts/CC...8/?image=large
So then this would work
Old 10-04-2009, 07:28 PM
  #35
mjr46
mjr46's Avatar
you need to make sure those lifters are retro fit
mjr46 is offline
Old 10-05-2009, 02:19 AM
  #36
sgarrelts01
So if they are retro lifters do they still need the link bars.
This is a retro kit, but the lifters don't have the link bars.
It says something about the base size will not fit HO motors, so i take it this is the kit i need, and then i would also need the Retro Fit thing.
$hit i am lost
I want to make my block roller, with the cam, lifters all that good stuff.
What do i need.
i don't want to spend 400-700 get the wrong **** and then install it.
Old 10-05-2009, 08:12 AM
  #37
mjr46
mjr46's Avatar
$hit i am lost
What do i need.
sorry to confuse you that kit may work, it says it has a reduced base circle roller cam and I was only going off the pic and pic may not be correct, if it's a reduced base circle cam then it should come with factory roller lifters and all you'd need is the spider retainer and h-bars.......also that other cam you listed had almost .600 lift, to much cam most likely for the intended build. the one in the kit you just listed would be better
mjr46 is offline
Old 10-05-2009, 01:19 PM
  #38
sgarrelts01
I was told today if it was not a 351 i do not need a reduced base cam.
So if i do need one, i just order any lifters i want, get the spyder retro fit, and then just call some place an tell them i need a reduced base cam.
JayGee
09-15-2015 12:41 PM
unit91
09-15-2015 09:53 AM
09-10-2015 08:39 PM
Other Professional Racing
09-10-2015 11:41 AM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
Quick Reply: What Size Push Rods
